2002 Chevy Trailblazer Ball Joints
2002 CHEVROLET TRAILBLAZER
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
RCSEY
Is there a trick to pressing "Out" the original ball joints from the lower control arm? Do you have to grind off the crown top of the ball joint to press the old joint through?
Dec 23, 2007 at 9:32 AM
SERVICE WRITER
  • 9,123 POSTS
There is a flange that first needs to be removied.
https://images.2carpros.com/forum/automotive_pictures/30961_fla_1.jpg
Dec 23, 2007 at 9:40 AM
RCSEY
I took the edges of the flange. However the ball joint press I got from the parts store did not have the correct fittings for the Trailblazer. So I had to get the ball joint pressed out at the local Midas. 15$, it was worth it!
Dec 24, 2007 at 5:28 AM
