2002 Chevy Trailblazer air condtioning cuts out while drivi
ANDREW98
  • 2002 CHEVROLET TRAILBLAZER
  • 6 CYL
  • 4WD
  • 143,000 MILES
I have a 2002 trailblazer, my a/c works great when I drive at about 1500 rpms (city driving), when I cruise down the highway at 2000 rpms the a/c cuts out every once in a whille. It blows warm for about 1 min then the pump kicks back on and it gets cold again. It will do this about 5 times in an hour. I had the a/c system checked out by a profesional and he replaced the pressure switch on the a/c pump, also recovered the system and put 1.8lbs of R134a in, and now this is what it is doing, I would perfer not to take it to him again. Please give me some advice on what it might be
Tuesday, July 27th, 2010 AT 1:06 AM
Could be freezing up and blocking off the orifice tube, air blend door actuator malfunctioning, pressure switch, magnetic clutch, AC control switch, temperature sensor and the HVAC control module
Tuesday, July 27th, 2010 AT 2:29 AM
