2002 Chevy Trailblazer AC Levels
JOSEPH VASQUEZ
  • 2002 CHEVROLET TRAILBLAZER
Air Conditioning problem
2002 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic
I have a 2002 and my AC goes only to level 4 when it should go to level 5 what is the problem with my AC unit?
Monday, April 14th, 2008 AT 9:29 PM
RHALL77
  • 3,361 POSTS
Are you saying the fan doesnt blow that high. Sould like a blower resistor is shorted and needs to be replaced
Tuesday, April 15th, 2008 AT 7:25 AM
JOSEPH VASQUEZ
If so then why does the 1, 2, 3, 4, levels work then when you switch to the 5th then it shuts off. Does the 5th level have its own resitor. It would seem logical to only have one resitor for the control levels, then to have just a seperate one for the 5th level and one for the other four levels or does each level have its own resistor?
Tuesday, April 15th, 2008 AT 1:56 PM
RHALL77
  • 3,361 POSTS
Some of them had a blower motor module (resistor)that controlled them. Yes it would and could only take one speed out. I would check there. It is located under the passenger side dash.
Tuesday, April 15th, 2008 AT 2:23 PM
