2001 Chevy Trailblazer license plate light
2001 CHEVROLET TRAILBLAZER
TB2001
The lights on either side of the plate will not work. I have changed the bulbs but can't tell what fuse it would be?? IF not the fuse any other suggestions?
Nov 19, 2009 at 12:16 PM
  • 110,244 POSTS
I believe if you follow the wiring from them it will lead you to a connector that plugs in. Remove that and make sure it is clean and tight (not corroded) and using a test light, make sure there is power to the connector.
Let me know what you find.
Dec 1, 2009 at 12:07 AM
