2001 Chevy Trailblazer fuel system
95,000 MILES • 6 CYL • 4WD • AUTOMATIC
MM733
my truck will not let me pump gas it keeps kicking it out like its full even when i use a gas can it over flows, i pulled down the tank and checked all the lines to see if anything was cloged and seen nothing wrong. there is a box that gas lines run to up by the back bumper i was woundering if this had something to do with it?
Oct 16, 2009 at 9:30 AM
  • 110,246 POSTS
There is a breather that follows the filler tube to the tank. Its purpose is to allow air to exit the tank as fuel enters. Chances are there is an obstruction or damage to it. CHeck it. You may want to get a wire or something you can run through the hose to check for obstruction.
Let me know what you find.
Dec 1, 2009 at 5:39 AM
