1998 Speedometer/Odometer/Cruise
JPH3
1998 s-10 blazer, 80k, 4.3 V-6 4x4
So... I am looking to get an answer on a Speedometer/odometer/Cruise that is not working.
We have replaced the speed sensor, put in a different blinker assembly, checked power in/out of the fuse boxes, even tried a different cluster... and the result is the same. Everything else on the cluster works fine, but the speedo doesn't move, and the odometer doesn't roll...
Any thoughts /Suggestions?
Anything is much appreciated
Mar 7, 2007 at 4:51 PM
2CARPRO JACK
  • 11,533 POSTS
Try the repair manual link at the bottom of main forum page.All wiring diagrams are in there so you can see if there is anything else in the system that could be keeping it from working. Might need a new cluster
Mar 8, 2007 at 12:01 AM
