1996 Chevy Trailblazer Brake light does not go out
96,000 MILES • 6 CYL • 4WD • AUTOMATIC
GIPPER
I had a bad brake line (leaking) I replaced the line and bled the brakes. The brake light in the dash will not go out. I drove all around town hoping it would go out. It did not. The brake pedal is almost at the top. I double checked the fluid level in the master cylinder it is is full. Can you help?
Mar 19, 2009 at 11:23 AM
BLACKOP555
  • 10,386 POSTS
what color light?
is the levelproperly full?
disconnect level sensor on the master cylinder, does light go off?
make sure the float on the level is up t the top. it could be haning up in the cylinder. try tapping on the master cylinder resevoir.
Mar 19, 2009 at 1:38 PM
