1992 Chevrolet S-10 Blazer Tire Rub
MAKINTIRESMOKE
Recently i mounted over sizedd tires on my blazer. The originals were 235/75r15, hte new ones are 31/10.50r15. The new tires rub on turns Ive beat the wheel wells in but they still rub sometimes. A friend told me that i could tighten the torson bars to lift the front end and possibly remedy this problem. Is this possible, and if so what affect will it have on the car. (the car is a piece of crap I an just running it into the ground. But i dont want the tires to blow out on me. Its also a daily driver.) Also the left rear tire is wearing on the inside what could cause this.
thanks.
Dec 29, 2006 at 10:28 AM
SACRILIDGE06
  • 13 POSTS
You can find spacers that will fit the hubs making the tires sit out further.
Jan 17, 2007 at 11:02 AM
MAKINTIRESMOKE
thank you i will try that
Jan 17, 2007 at 11:16 AM
INDYUKE
  • 416 POSTS
Cranking up the torsion bars will lift the front of the vehicle. You can actually lift it quite a ways this way. Just make sure you don't over-extend your suspension, shocks, brake lines, etc. Then have your vehicle re-aligned.
Jan 17, 2007 at 11:30 AM
Suggested Repair
The front can be raised by adjusting the torsion bars, but do not overextend the suspension, shocks, or brake lines. After the height change, have the vehicle realigned.
Conversation Summary
The owner installed larger 31x10.50R15 tires on a 1992 Chevrolet S-10 Blazer and still has occasional rubbing in turns after modifying the wheel wells. A user suggested wheel spacers. The expert said tightening the torsion bars can lift the front substantially if suspension travel, shocks, and brake lines are not overextended, followed by a realignment. Inside wear on the left rear tire was mentioned but not specifically diagnosed.
