1991 Chevy Trailblazer clutch sleeve
100,000 MILES • 6 CYL • 2WD • MANUAL
RANDMANN77
how do i bleed a clutch system
Jan 15, 2009 at 12:06 PM
MMPRINCE4000
  • 8,548 POSTS
Bleed from slave cylinder. Usually the clutch MC is higher than slave, if so, fill up MC and open clutch slave bleeder, If no fluid comes out, you may have a restriction in line, or leak.
You can also use a hand held vacuum pump on the slave bleeder screw to bleed system.
If you get a lot of dirty fluid out, then I would clean and flush the entire clutch system.
Jan 15, 2009 at 9:55 PM
