1988 Chevy Trailblazer back fireing and high idle
JACKIE BYRD
Engine Mechanical problem
1988 Chevy Trailblazer 6 cyl Two Wheel Drive Automatic
When I start the motor it is at a high idle and then it goes to a slower idle then back fires in the throtle body and motor dies
Sep 7, 2010 at 9:02 AM
  • 75,988 POSTS
Clean out the idle air control valve and test the throttle position and manifold absolute pressure sensors and also check the fuel pressure and look for vacuum leaks-
Sep 7, 2010 at 11:37 AM
