2004 Chevy Tracker will not fire
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
SAMFIELDS
we replaced computer and fuses and still did not repair it
Feb 12, 2010 at 8:47 AM
  • 75,988 POSTS
2004 Chevy Tracker will not fire -Did you meant it cranks over and will not start if so do below and get back asap with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jul 17, 2020 at 8:53 AM
