2002 Chevy Tracker Tapping noise in the engine
215,347 MILES • 4 CYL • 4WD • AUTOMATIC
CARLA ERWIN
There is a tapping noise in the motor what could this be. So I will know what problems could exist since I'll have to have it checked. I know nothing about cars. Just basics. And wouldn't want to spend money not needed. I haven't got a mechanic
Sep 3, 2010 at 2:12 PM
BILLYMAC
  • 2,204 POSTS
Hi carla.
Well a tapping noise really depends on where at in the engine that it is located.ie.on the top of the eng this would be a lifter noise. on the sides of the engine this could be a wrist pin or piston prob.
on the bottom of the engine this could be a crankshaft or rod bearing or main bearing
However with the miles on your engine it could be major . i would change the oil and add one qt of trans fluid to the oil. the oil changers will tell you not to do this but trust me it is the only chance of not doing major repairs..
Sep 14, 2010 at 12:45 PM
