2001 Chevy Tracker Problems after radiator replacement
120,000 MILES • 4 CYL • 2WD • AUTOMATIC
SACREDWOLF
  • 9 POSTS
I just changed out the radiator. All the hoses are connected as they should be, I put in a gallon of half water/ half coolant in before I started up. It took for ever for it to reach normal temp. I took it for a spin and it shot up to the RED zone and stayed there till I got it back to the house about 3/4 of a mile away.
I was thinking maybe the thermostat is messed up, but really not sure. Any idea of what could be the problem?
Thanks,
T
Jan 25, 2009 at 6:51 AM
CALYPSO93
  • 43 POSTS
usually when this happens it's due to air in the system. run it from cold to hot a few times, and make sure the rad and overflow are full when colld
Jan 25, 2009 at 8:42 AM
