2001 Chevy Tracker cycles on and off
2001 CHEVROLET TRACKER
JMURILLO
Air Conditioning problem
2001 Chevy Tracker 6 cyl Two Wheel Drive Automatic 120k miles
ac cycles on and off constantly. refrigerant is good, exp. valve is new. cycling switch if new. Can you suggest anything?
Mar 21, 2010 at 8:15 AM
LEGITIMATE007
  • 5,121 POSTS
if your sure the refrigerant is high enough then check the pressure switch, when the refrigerant isnt high enough , there will not be enough pressure and the clutch will cycle on and off, if you are filling it your self, sometimes the gauge is off, so as your filling it and the a/c is running. as it gets full enough it will cycle lesss and less untill it only cycles like once a minute if that.
Mar 21, 2010 at 8:18 AM
JMURILLO
approx. how many oz. of refrigerant should be put into a system?
Mar 21, 2010 at 8:29 AM
LEGITIMATE007
  • 5,121 POSTS
that should be indicated on the little sticker in the engine compartment, right by the hood locking mechanism.
Mar 21, 2010 at 8:31 AM
