Engine low power going up hill?
164,000 MILES • 4 CYL • 2WD • AUTOMATIC
PALBRIGHT60
lost power going up hill, fluttering air sound. was 1 quart low on oil & transmission fluid. did oil and transmission fluid and filter change. new fuel pump. better power, but still have fluttering air sound when pushing to passing gear..........help!!!
Aug 5, 2009 at 11:27 PM
2CARPRO JACK
  • 11,533 POSTS
Does the exhaust sound like a hair dryer blowing? You may have a partially restricted exhaust system (cat converter). Try loosening the exhaust flange where it bolts to the manifold and driving it.The vehicle will be loud, but if the cat is partially plugged it will have its uphill power back
Aug 11, 2009 at 12:43 AM
SARCASTICSPAZZ
  • 5 POSTS
I'm having the same issue, did you ever verify the problem?
Jun 9, 2020 at 2:10 AM
  • 55,691 POSTS
They never came back so we don't know. Can you please shoot a quick video with your phone so we can hear the noise? that would be great. You can upload it here with your response.
Jun 9, 2020 at 4:46 AM
SARCASTICSPAZZ
  • 5 POSTS
I took three videos, or tried to anyways. First two with windows up. Third one with them down. Pretty hard to hear it over the engine in the video. When I tried to capture the noise it was more sustained this time. Like sssssss, usually it's more like a ts-ts-ts-ts. Also I didn't realize this page was for the 4 cylinder. Mine's the 2.5 v6 4x4. Any help is appreciated.
Jun 9, 2020 at 12:11 PM
  • 55,691 POSTS
Thanks for the videos, it only makes the noise while moving correct? can you say if the noise is coming from the front or rear or middle? I would put the car up on jack stands. here is a guide:
https://www.2carpros.com/articles/jack-up-and-lift-your-car-safely
Or car hoist and put it in gear and let the drive-train roll in third gear or drive. While running move around the car underneath to pinpoint the noise generator. More videos of the noise while doing this would be great. It sounds like a differential or transfer case issue. Please let us know. Please let us know what you find. We are interested to see what it is.
Jun 10, 2020 at 3:08 AM
SARCASTICSPAZZ
  • 5 POSTS
I'm starting to think fan clutch. Randomly caught this video: https://youtu.be/BR-uLMTaOXY
My fan free spins pretty easy. But I'd think it would make the noise while parked and revving too, but it sounds fine. I don't have a level area to lift the car and run it up to speed. I'll probably end up taking it to a mechanic. Took another video with windows down because it's doing it more under less load now. You can hear towards the end when it kicks into cruising gear it goes away. Didn't catch it in this video, but I swear I can hear belt squeal from time to time too. Still nothing solid though. I'll bring any results I get.
Jun 15, 2020 at 2:03 PM
SARCASTICSPAZZ
  • 5 POSTS
Solved! It was a problem of my own design. Last year I put new catalytic converters on. I rushed the job towards the end because I was tired of rolling around in the mud and rain. Anyway, the doughnut gasket between the Y pipe and the straight catalytic converter with the spring bolts has worked itself loose. The reason it wasn't making the noise while parked is because there was no road vibration, not from lack of transmission engagement. The reason it felt gutless up hill is because the tracker is generally gutless uphill and the noise was "scaring" my foot off the gas. I figured it out when I heard the noise after hitting a pot hole at lower rpms and speed. The noise "bounced". It then occurred to me. The fluttering noise was the spring bolts trying to hold the pipes together. In the picture you can see the doughnut gasket is crooked. I'm guessing the belt noise I thought I'd heard was whistling. So this problem was specifically mine, but I figured I'd write it up anyways. Maybe someone can learn from my mistake.
Jun 17, 2020 at 2:19 AM
  • 55,691 POSTS
Good job, noise issues can be difficult. Glad you could get it fixed, that kind of problem can be tough. Please use 2CarPros anytime we are here to help.
Jun 18, 2020 at 4:48 AM
SARCASTICSPAZZ
  • 5 POSTS
Final Verdict.
Must have been chunks of old catalytic converter in the Y pipe. (Or I have bigger issues) But they dislodged and ended up clogging the lower catalytic converter. That caused back pressure that blew out the donut joint gasket thingy, and robbed all my power. So there's my lesson; When you replace the upper catalytic converters, check all your lower pipes too. I really should have just replaced all three catalytic converters on the first go...
Jun 24, 2020 at 6:23 AM
  • 55,691 POSTS
Yep, I have seem that before. Nice work, we are here to help, please use 2CarPros anytime.
Jun 25, 2020 at 3:56 AM
