2000 Chevy Tracker head
TJBOWHUNTING
Engine Mechanical problem
2000 Chevy Tracker 4 cyl Four Wheel Drive Automatic
on a 2.0 dohc if a valve bent will it crack a piston
Feb 6, 2010 at 10:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
i believe it's an interference engine so it's likely it did but only way to tell is to run compression check on cylinders.
Apr 22, 2010 at 4:00 PM
