1999 Chevy Tracker transmission repair
SUE HOVIS
Transmission problem
1999 Chevy Tracker 4 cyl Automatic
transmission will not go into reverse butpulls forward in all gears except park
Apr 19, 2010 at 2:56 PM
BLUELIGHTNIN6
  • 16,542 POSTS
First check the fluid level, if its low add some asap. If the fluid level is fine, look at the fluid is it dark or burnt smelling, feel it does it have metal shavings in it?
It may be worth your while to get a transmission filter change and a flush out of the system. If this doesnt help , the reverse clutch inside the transmission is likely broken and in need of replacement, which is usually more expensive than a rebuilt or used transmission replacement..
Apr 22, 2010 at 3:31 PM
