1999 Chevy Tracker TRANSFER CASE
JOEBUF
1999 Chevy Tracker 4 cyl Four Wheel Drive Automatic
THE HANDLE ON THE TRANSFER CASE WON'T MOVE AT ALL IT'S BEEN IN REAR WHEEL DRIVE FOR A WHILE NOW, HOW CAN I GET TO PLACE IT FROM REAR WHEEL TO FRONT WHEEL , IS THERE A LOCK SOMEWHERE ON IT OR IS THE TRANSFER CASE UNIT NO GOOD? I CAN BUY A USED ONE RIGHT NOW. SHOULD I?
Sep 4, 2010 at 12:06 PM
MADMIKE1735
  • 951 POSTS
the handle on the floor correct???? if it wont love, the linkage may be siezed... bring it to a garage for analysis.... they should be able to remove the cable from the transfercase and put it in manually.... assuming its not vacuum controlled.... either way, get the linkage checked out.
Sep 4, 2010 at 12:30 PM
