1999 Chevy Tracker DOME LIGHT
70,000 MILES • 4 CYL • 4WD • AUTOMATIC
CRFOURNIER
HI
MY DOME LIGHT DOES NOT WORK, WHEN I DO REPLACE THE FUSE, IT WILL WORK ONLY FOR A FEW MINUTES, I ASSUME IT COULD BE THE PART THAT CLOSES AND OPEN THE LIGHT WHEN I OPEN AND CLOSE THE DOOR, THE DOME LIGHT SWITCH ALSO ONLY WORKS FOR A FEW MINITES, I HAVE TRIED REPLACING THE FUSES NUMEROUS TIMES WITH SAME RESULTS,
iF IT IS THAT PART THAT IS DEFECTIVE, WERE WOULD IT BE LOCATED
tHANKS
RAY
Feb 12, 2010 at 7:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
the door ajar (aka door jamb) switch is located in the door jamb of each door.
Apr 22, 2010 at 3:48 PM
