HI
MY DOME LIGHT DOES NOT WORK, WHEN I DO REPLACE THE FUSE, IT WILL WORK ONLY FOR A FEW MINUTES, I ASSUME IT COULD BE THE PART THAT CLOSES AND OPEN THE LIGHT WHEN I OPEN AND CLOSE THE DOOR, THE DOME LIGHT SWITCH ALSO ONLY WORKS FOR A FEW MINITES, I HAVE TRIED REPLACING THE FUSES NUMEROUS TIMES WITH SAME RESULTS,
iF IT IS THAT PART THAT IS DEFECTIVE, WERE WOULD IT BE LOCATED
tHANKS
RAY
tHANKS
RAY
Feb 12, 2010 at 3:10 PM
