1999 Chevy Tracker compressor
110,000 MILES • 4 CYL • 2WD • MANUAL
MALLON500
  • 6 POSTS
The AC COMPRESSOR clutch started making a loud screehing noise and appeared to be slapping on and off. The belt is in good condition. Is the clutch servicable, or could it be a relay problem? Please help!
Sep 7, 2010 at 7:55 AM
DOCFIXIT
  • 18,828 POSTS
Hi
What you are describing is compressor failure and locking up causing clutch to smoke. With engine off grab clutch shoe and try and rotate if it turns then it is clutch assembly.
Let me know
Thanks for donate
Sep 7, 2010 at 8:06 AM
