1999 Chevy Tracker camshaft position sensor
1999 CHEVROLET TRACKER
150,000 MILES • 4 CYL • 4WD • AUTOMATIC
PREB623
Hi there,
A diagnostic showed trouble with camshaft position sensor. I replaced the sensor but the car won't start. It tries, and when depressing the gas I hear a "popping" sound like engine trying to start. Can you tell me what might be wrong and how I may be able to fix it? Is the position of the sensor important and could that be why it isn't starting?
Thanks!
May 28, 2010 at 4:52 AM
DOCFIXIT
  • 18,828 POSTS
Was code P0340? did you check to see is sensor ring is turning, no missing teeth or debris?
May 28, 2010 at 5:27 AM
PREB623
I actually had the diagnostic done at Goodyear, they told me the problem was the camshaft sensor. Not sure what the code was. I can call and ask them?
May 28, 2010 at 5:32 AM
