1999 Chevy Tracker
150,000 MILES • 4 CYL • 4WD • AUTOMATIC
MARK DUFF
My tracker would run at idle but then dies when i give it gas. Now it wont start at all. I have already replaced the fuel filter,and that didn't help. What does this sound like?
May 31, 2010 at 2:50 PM
  • 75,988 POSTS
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 31, 2010 at 10:56 PM
