1994 Chevy Tracker tune up issue
100,000 MILES • 4 CYL • 4WD • AUTOMATIC
MEATZY
JUST TUNED UP, ROTOR, CAP,LUGS AND WIRES AND THE CAR RAN SAME FOR ONE DAY, BUT THE NEXT DAY IT HESITATED AND THE CHECK ENGINE LIGHT CAME ON. I OPENED THE HOOD AND FOUND THE PLUG WIRES AND COIL WIRE WERE BLOWN OFF THE CAP? I REPLACED THEM TO THE CORRECT POSITION ON THE CAP AND THE CAR DID NOT EVEN CRANK AFTER THIS? WHAT'S GOING ON?
Sep 14, 2010 at 2:40 AM
BILLYMAC
  • 2,204 POSTS
remove the cap crank eng is there spark
check and make sure rotor is not broken
remove coil wire from distrib crank any spark?
Sep 14, 2010 at 12:32 PM
