2004 Chevrolet Tahoe Won't Start
DTURNER45
2004 Tahoe 54800 4.8 I tried to start one morning and it just wouldn't start..after a couple of tries it starts up and runs fine...A mechanic said it was a bad fuel pump and installed one and it worked fine, but the next morning it was the same thing...I get electrical power but the engine just won't start, what could be the problem?
Sep 13, 2007 at 12:54 PM
WRENCH
  • 57 POSTS
Your subject said wont turn over, but you also said it wont start, if you had it checked out by a mechanic and r&r fuel pump, have you checked fuel filters, fuel pressure, and regulator. Also have you checked for any engine codes (OBD 2 scanner). So If it cranks over, check for fuel pressure and engine codes first.
Sep 13, 2007 at 1:52 PM
Suggested Repair
If the engine cranks, check fuel pressure, the fuel filter, and the fuel pressure regulator, and scan for OBD-II codes before replacing more parts.
Conversation Summary
A 2004 Chevrolet Tahoe with a 4.8 engine sometimes will not start in the morning, then starts after several attempts and runs normally. A fuel pump replacement helped briefly, but the problem returned the next morning despite electrical power being present. The expert notes the difference between not cranking and not starting, and recommends checking fuel pressure, the fuel filter, the regulator, and engine codes if the engine cranks.
