vent valve and canister with drag
AMYLOU
what is this? is it pertinant to change this immediately. my check engine light went on in my 2001 chevy tahoe LS that has 85k. Im not sure of my engine size. I had a diagnosis and they said that my vent valve and canister with drag needs to be changed. They said that it had dirt in it. People that I have asked have no clue what this is.
May 3, 2007 at 5:46 AM
RUDPRO
  • 224 POSTS
That's the Evaporative Emission Control System. It traps fuel vapors that escape from the gas tank, throttle body and intake manifold. It stores the vapors in a charcoal cannister and when the engine is running it releases the vapors back into the engine to be burned. You could have poor idling, stalling or a strong smell of fuel if this system malfunctions. If the check engine light came on it probably needs to be changed but you might want to get a second opinion.
May 18, 2007 at 11:57 AM
