suburban overheating
AUSTINSTEVE
i just replaced the water pump on my 97 suburban. it was making a sporadic squealing-grinding, so i thought it could be the bearings on the pump- but now that the new pump is in, it is overheating and the heater doesn't blow hot air. what could the problem be?
Dec 19, 2006 at 8:14 AM
BACKYARDMECHANIC
  • 337 POSTS
Sounds like you may have air trapped in the system. I not all that familar with your make and model but I 'am sure there is a way to bleed the air out of the system. Good luck
Dec 20, 2006 at 11:38 AM
