I have a 1997 2 door tahoe 2 wheel drive with a vortec 350 with 85000 miles. I live in Houston Texas and my truck is not a daily driver. The problem i'm having is that if I don't start my truck daily after 2 days of sitting in the garage it will be dead. I replaced the battery and alternator and still having the same problem. Can the starter be the problem?
Thanks,
Joe Robles
SPONSORED LINKS
Monday, February 12th, 2007 AT 8:32 PM
JEFTFIELDS
MEMBER
It sounds like you have something draining your battery like a dome light, glove box light, something is on, and thats why your barrery is dead after two days.
Monday, February 12th, 2007 AT 10:57 PM
GROUNDZERO
MEMBER
Thats what I thought also and I checked them all could not find one that was staying on. Some one told me it could be the fround wire. Is that possible?
SPONSORED LINKS
Tuesday, February 13th, 2007 AT 8:00 AM
JEFTFIELDS
MEMBER
I wouldnt think so, but to see if you have a drain take a test light, disconect the neg, battery cable and put the test light between the two conections if there is abright light you have a drain.
