Spark plugs on 2001 Tahoe 5.3L
LKILROY
I want to change the plugs on my Tahoe. I've done this on other cars but on the Tahoe they appear to be encased in a metal cylander. Does this just protect the plugs? Does it pull off ? I was afraid to pull too hard. Also, will it hurt the cooling system if I use something other than Dextran which cost about 100.00? Thanks
Jun 7, 2007 at 7:42 AM
SERVICE WRITER
  • 9,123 POSTS
The metal cylinder is a heat sheild and can remain right where it's at. Use and extension to get down in.
Dex-cool is a 5-year 150,000 mile coolant, you can use extended life coolant which has a long life as well. You can go to standard green coolant, but then you need to change it every 2 years/24,000 miles. I would stay with Dex-cool on that one.
Dextron is transmission fluid.
Jun 7, 2007 at 11:45 AM
