replace front marker lights - 1999 Tahoe 4x4
BOBFAKE
130,000 miles and the best vehicle I have ever owned (and I've had 40+)
I need to replace the bulbs in the front marker lights to pass inspection. It seems the lens is part of the oeverall grill assembly, but I'm sure I must be missing the simply way to replace these bulbs. Any assistance is greatly appreciated.
Jul 17, 2007 at 9:48 AM
LEB
  • 45 POSTS
One of the "marker lights" is actually just for looks, but that doesn't really matter for your question.
Unfortunately, there is no 'easy' way, although taking the grill off is not that difficult. You need be careful about not breaking the clips when you remove the grill.
If your headlights are anything like mine were (glazed over so much that they gave more of a glow instead of a beam) you may want to take the opportunity to change the headlights out. I purchased a set (which included the headlights, blinker/flashers and markers) on ebay.
Jul 17, 2007 at 2:42 PM
BOBFAKE
Thanks for the advice,but I found out that by removing the 4 screws and the the front turn signal assembly gave me direct access to the marker light. Took about 3 minutes to do both sides.
Thanks!
Jul 18, 2007 at 9:43 AM
LEB
  • 45 POSTS
Excellent! I'll have to remember that!
Since I was changing the headlights, I had to remove the grill anyway.
Thanks for the pointer.
Jul 18, 2007 at 10:34 AM
