Removing Fan/Clutch from 98 Suburban
DAVIDV07
Ok... call me old, but this is the newest vehicle I own and the water pump crapped out. I tore into it like I do to all the 350ci's I've owned. I removed the bolts attaching the pulley to the pump and scratched my head when the pulley came loose but the fan/clutch didn't. I've struggled with it for about an hour, until I had to ask God to forgive my mouth and quit for the night.
How does the fan/clutch come off. There's what looks to be a big nut, maybe 1 1/2" dia about 2" long between the fan and the water pump, looks more like a spacer. Is this thing threaded into the pump?
My Haynes manual is no help this time, it shows pictures and descriptions of the water pumps I'm use to seeing.
Any suggestion appreciated,
-Dave
Feb 8, 2006 at 11:18 AM
CHEVY350GUY
  • 109 POSTS
yes it is screwed in to the pump, it is either 1 3/8'' or 1 /12''. the easiest way is to put the pully and belt back on and remove this first.
Feb 8, 2006 at 11:24 AM
DAVIDV07
[quote:19d9f301ba="chevy350guy"]yes it is screwed in to the pump, it is either 1 3/8'' or 1 /12''. the easiest way is to put the pully and belt back on and remove this first.[/quote:19d9f301ba]
Thanks for the response. Left or Right hand thread?
Feb 8, 2006 at 11:33 AM
CHEVY350GUY
  • 109 POSTS
i believe right
Feb 8, 2006 at 11:40 AM
