Power steering...
LESLIE TABOR
99 Chevy Tahoe, 5.7L-8...
Two power steering lines, both steel lines? are the design of each line interchangeable...both configured the same?
Both lines are leaking...need to change out both. Any special precautions, or processes for changing out lines...do I need to bleed lines after changing lines out, etc?
Jul 20, 2007 at 6:54 AM
LEB
  • 45 POSTS
The lines are not interchangeable on my 96 and 97. When you replace the lines, the way you bleed it is by starting the truck and turning the wheel full left and the right, and continue.
If I recall correctly, the replacement lines had directions on how to bleed.
I do remember I became frustrated getting the new lines to connect to the pump. It took several tries, but finally connected.
Aug 1, 2007 at 11:23 AM
NACH
THE CURE FOR A TAHOE THAT HAS STEERING PROBLEMS W/ EVO STEERING IS GM PART # 19168825 COMES WITH INSTRUCTIONS DONT SPEND THOUSANDS LIKE I DID
Nov 30, 2007 at 6:34 AM
