Fuel Pump has been replaced 7 times
DEBOROAHFRAZIER
I have replaced my fuel pump 7 times in the past year and a half. Is there something that is making the fuel pump go bad prematurelly? I have replaced it with an AC Delco the last two times, it has only been three weeks since I replaced it last.
Chevrolet
Tahoe limited
4d 2wd
2000
5.7 engine
V8
140000 miles
Aug 6, 2007 at 12:46 AM
SERVICE WRITER
  • 9,123 POSTS
The fuel pump electrical connectors have been a problem with those for one. Use an ac delco pump when replacing it. The filter should have changed also.
Or it is getting mis-diagnosed.
Aug 6, 2007 at 12:50 AM
DEBOROAHFRAZIER
[quote:28ee7739df="Service Writer"]The fuel pump electrical connectors have been a problem with those for one. Use an ac delco pump when replacing it. The filter should have changed also.
Or it is getting mis-diagnosed.[/quote:28ee7739df]
THe last 2 have been ac delco.
Aug 6, 2007 at 3:43 AM
DEBOROAHFRAZIER
The last 2 have been ac delco fuel pumps.
SERVICE WRITER
  • 9,123 POSTS
Waht about the connector or filter...I think this may been misdiagnosed 6 times. :shock:
The connector part number is 88988598 available at the dealer.
Aug 6, 2007 at 3:50 AM
JDMIDDLETON
[quote:3487d1cbb9="Service Writer"]Waht about the connector or filter...I think this may been misdiagnosed 6 times. :shock:
The connector part number is 88988598 available at the dealer.[/quote:3487d1cbb9]
I replaced my pump 2 times without changing to connector. The third time i used an acdelco and it went out the next day, i put a new connector on it and its been good ever since. when you changed it the first 6 times unhooking the connector removed enough corosion to allow connection for some time but not permenantly.
Aug 22, 2007 at 6:20 AM
SERVICE WRITER
  • 9,123 POSTS
Thanks for the confirmation JD
https://images.2carpros.com/forum/automotive_pictures/30961_thanksinfo_2.jpg
Aug 22, 2007 at 12:07 PM
