brake piston problem
2001TAHOEEDDY
While changing the rear brake pads on my 2001 Chevy Tahoe(96320 miles) the drivers side went well, but on the passengers side I didn't compress the pistons together. As I compressed the top piston, the bottom one extended and the boot swelled. As I compressed the bottom piston, it began to leak and the boot was not retracting well. Now the piston is compressed and the boot is not seated properly and I have no idea what to do next. Do I have to replace the whole housing that holds the 2 pistons, which would mean bleeding the brakes, which I'm nervous about. I'd appreciate any advice,as the truck is sitting in my garage until I figure out what to do next.
Also, what is the best repair manual to get?
Thanks so much for any help!
Nov 12, 2007 at 9:53 AM
BMRFIXIT
  • 19,053 POSTS
[quote:65c18d85c9="2001tahoeeddy"]While changing the rear brake pads on my 2001 Chevy Tahoe(96320 miles) the drivers side went well, but on the passengers side I didn't compress the pistons together. As I compressed the top piston, the bottom one extended and the boot swelled. As I compressed the bottom piston, it began to leak and the boot was not retracting well. Now the piston is compressed and the boot is not seated properly and I have no idea what to do next. Do I have to replace the whole housing that holds the 2 pistons, which would mean bleeding the brakes, which I'm nervous about. I'd appreciate any advice,as the truck is sitting in my garage until I figure out what to do next.
Thanks so much for any help![/quote:65c18d85c9]
replace the caliper
after all together OPEN BLEEDER UNTILL DRIP FLUID
CLOSE BLEEDER
HAVE A HELPER STEP ON BRAKES AND HOLD IT DOWN U OPEN THE BLEEDER LET THE AIR OUT
AND CLOSE
REPEAT AS NEEDED MAY BE 2 OR 3 TIMES
MAKE SURE U HAVE BRAKE FLUID IN THE MASTER CYL
GOOD LUCK
Nov 12, 2007 at 10:48 AM
