2010 Chevy Tahoe trouble codes
2010 CHEVROLET TAHOE
1,800 MILES • V8 • 2WD • AUTOMATIC
NUKCURV51
i just installed E3 spark plugs in my 2010 tahoe 5.3 motor. the plugs where the only change that i made. i turned the car on and it ran rough. the DIC gave me service stabilitrack and service traction control. i got trouble codes P0300 and P3400 when i plugged my reader into the obd port. which is miss fire and and bank 1 shutdown i believe. the idle is running really rough. i pulled and reinstalled all the plugs torquing to specs. what would cause the problem of miss fire after just changing the plugs
Jul 23, 2010 at 9:05 PM
What is it misfiring prior to you replacing the plugs? If not could be the plug type or the gap, loose contact between the plug and wire.
You sure this P3400 is not P0340 that relates to a camshaft sensor malfunction
Jul 23, 2010 at 9:47 PM
