2007 Chevy Tahoe Won't start
2007 CHEVROLET TAHOE
16,000 MILES • V8 • 2WD • AUTOMATIC
WOPPY BALBOA
What would cause the vehicle to suddenly have no power what so ever? It's as if the battery is not even hooked up, but it is. No lights, no clicking, no anything. The battery is only about 6 months old. Vehicle was running fine pulled up at home, and later went to lock doors with key pad and noticed that it didn't work. Tried to start and nothing. Any suggestions, thanks?
Oct 8, 2010 at 2:00 AM
JDL
  • 16,098 POSTS
I'd make sure the battery has a full charge. Check that all battery connections coming and going are clean and tight on both ends. Next, I'd go to a fuse box, pull an applicable fuse for any circuit you want to check, and see if there is voltage at the fuse, use a voltage tester. Some fuses are hot all the time, some go hot when you turn the key on.
Oct 8, 2010 at 2:14 AM
