2007 Chevy Tahoe Spark Plugs
2007 CHEVROLET TAHOE
60,000 MILES • V8 • 2WD • AUTOMATIC
CABBY92
just change the spark plugs and kbnow the car is idling rough and the "service stability track" light came on.
Jan 1, 2009 at 8:06 PM
BRIAN 1
  • 1,030 POSTS
did it run rough before you changed the plugs? why did you change the plugs,these are 100k plugs? what kind of plugs did you use?could pull each plug and see if any are cracked,or scan it and see what codes and which cylinder is missfiring. need more info,post back with any other questions.
Jan 1, 2009 at 8:51 PM
