2007 Chevy Tahoe Fuel Sending unit
40,000 MILES • V8 • 4WD • AUTOMATIC
JOHNLCROWE
What is the cost to replace the Fuel Sending unit.
May 28, 2010 at 2:47 AM
DOCFIXIT
  • 18,828 POSTS
Sender @$126 and labor in 3hrs shop rates vary across country average $90 per hr.
May 28, 2010 at 5:37 AM
JOHNLCROWE
I called a dealer a shop and they both quoted around $900.00.
Also, is this something that would be covered under warranty
May 28, 2010 at 7:05 AM
DOCFIXIT
  • 18,828 POSTS
Dealer maybe replacing entire fuel unit including pump that would be @$900. Not sure about warreny believe it was 36mo- 36000miles. You can ask GM rep number in owners manual or on line
May 28, 2010 at 7:32 AM
JOHNLCROWE
OK, that makes more sense. One more question then. My mechanic says he usually replaces the fuel pump at the same time. What is the downside if I don't replace the fuel pump and just address the sender?
May 28, 2010 at 7:39 AM
