2007 Chevy Tahoe Door lock and TPMS alarm
2007 CHEVROLET TAHOE
31,000 MILES • V8 • 4WD • AUTOMATIC
ICERACER26
The TPMS service alarm came on and at the same time the remote door stoped working. AS best i can tell the Remote Control Door Lock Reciever took a dump, do you agree? If so where is it located, i can change it out. Truck is 6 mounths out of warrenty and i did change both batterys in our remote,s.
Thanks Mark
Oct 10, 2010 at 5:01 PM
GMTECH
  • 537 POSTS
You problem could be as simple as reprogramming the receiver with updated info and replacing the fobs or replacement of the receiver and the fobs. There is a newer style fob available. If you want to change the receiver it is located behind the left rear upper trim pillar panel by the liftgate. You will still need a reprogram though
Oct 27, 2010 at 2:29 PM
