2006 Chevy Tahoe swap bench seats with bucket seats
20,000 MILES • V8 • 2WD • AUTOMATIC
DEMEPOLI
Is it possible to swap out the 40/20/40 second row bench with two bucket seats?
Mar 8, 2008 at 4:00 AM
MASTERTECHTIM
  • 4,750 POSTS
its possible. if you get the seats from the exact same vehicle. if not you will probably have to do some fabrication to make it fit right. my suggestion is get the bucket seats from the same kind of truck if possible.
Mar 8, 2008 at 4:11 AM
DEMEPOLI
so the bolts should line up...if I get the seats from another 2006 Tahoe. Thank you very much.
Mar 8, 2008 at 4:16 AM
MASTERTECHTIM
  • 4,750 POSTS
yes they will. all the trucks have the same bolt pattern stock, they just use the ones they need depending on the options, so either will fit.
Mar 8, 2008 at 4:18 AM
MASTERTECHTIM
  • 4,750 POSTS
ALSO IF YOU PUT IN THE BUCKETS AND IT LOOKS LIKE A HOLE IS MISSING YOU WILL HAVE TO CUT OUT A SLIT IN THE CARPET TO ACCESS IT.
Mar 8, 2008 at 4:19 AM
DEMEPOLI
thanks again. have a good weekend!
Mar 8, 2008 at 4:23 AM
