2005 Chevy Tahoe Windshield washer fluid sensor
102,000 MILES • V8 • 2WD • AUTOMATIC
SHIG1019
We have replaced both wind shield washer pumps and lines to stop the leaks. There are no more leaks, but we may have damaged the fluid level sensor in the resevoir because the check washer fluid message is still on. Do I need to replace the sensor or can I disable it some how?? If I need to replace it, how do I do that?
Nov 15, 2009 at 12:58 PM
  • 110,248 POSTS
if you cross the wires they should shut the light.
Nov 29, 2009 at 11:58 AM
