2005 Chevy Tahoe wheel barrings
2005 CHEVROLET TAHOE
93,900 MILES • V8 • 2WD • AUTOMATIC
TAMEIKA8
How much will it cost me for wheel barrings to be replaced or fixed on the tahoe?
Apr 8, 2009 at 6:40 PM
BMRFIXIT
  • 19,053 POSTS
Wheel Hub, Bearing, and Seal Replacement (RWD)
Removal Procedure
Raise and support the vehicle.
Remove the tire and wheel.
Remove the rotor. .
Remove the wheel speed sensor and brake hose mounting bracket bolt from the steering knuckle.
Remove the wheel hub and bearing (4) 15-series mounting bolts.
Remove the wheel hub and bearing mounting bolts (4), the 25/35 series.
Remove the wheel hub and bearing and splash shield from the vehicle.
Remove the O-ring seal from the steering knuckle bore, the 25/35 series.
Remove the wheel speed sensor mounting bolt (5).
Clean and inspect the O-ring seal, the 25/35 series.
Replace the seal if the following conditions exist:
Nicks
Cuts
Dry or brittle
Compression set
looking to spend about $300
Apr 8, 2009 at 11:03 PM
