2005 Chevy Tahoe Spark Plug Wire Removal On 2005 Chev.Tahoe
101,000 MILES • V8 • 4WD • AUTOMATIC
TARBABY
My spark plug wires seem to be glued onto the spark plugs and I can't pull them off. I've tried twisting the boot but no luck.[img:dfd70a942d]http://www.2carpros.com/forum/automotive_pictures/203163_IMG_1515_1.jpg[/img:dfd70a942d] Is there a special trick or tool for removing the wires that I should be using??
Jun 18, 2008 at 2:52 AM
RHALL77
  • 3,361 POSTS
if you are replacing them, just pull really hard. they will come loose.
Jun 18, 2008 at 3:02 AM
TARBABY
Thanks rhall77,
I'll just pull them out with a pair of pliers. I guess it's a good idea to replace them anyway.
P.S.- I'm making a donation to the site, thanks again for your help.
Jun 18, 2008 at 5:52 AM
BLACKOP555
  • 10,386 POSTS
you can use a pick and try to pull up on the bottom to release the suction, when you pull on them there is no air in them and it sucks on the plugs making it hard to come out, so twist and pull.
Jun 20, 2008 at 3:18 PM
