2005 Chevy Tahoe Engine Coolant Hot light came on
2005 CHEVROLET TAHOE
54,000 MILES • 4 CYL • 2WD • AUTOMATIC
NIKIGIRL
When it did this my husband put in more coolant. But, when I drove only about 10 miles, the light came back on. Is there a leak and how much is it going to cost to get it fixed??
Jan 27, 2010 at 1:35 AM
TOOOMANYTOYS
  • 513 POSTS
It could be a number of things causing the vehicle to overheat. While driving you should always monitor the coolant temperature gauge to avoid causing more damage. I would start with pressure testing the cooling system to see if there are any leaks.
Jan 27, 2010 at 1:43 AM
NIKIGIRL
How do you pressure test the coolant? Is it something that I will have to take to a mechanic to do and does it cost an arm and a leg?
Jan 27, 2010 at 1:47 AM
NIKIGIRL
the cooling system.how do I pressure test this?
Jan 27, 2010 at 1:50 AM
