2005 Chevy Tahoe
2005 CHEVROLET TAHOE
14,700 MILES • V8 • 4WD • AUTOMATIC
MUFFY'S 70 Z28
I appreciate the help I got to remove the u-joint from the shaft. However, I could not get the drive shaft out when I removed the 2 u-bolts at the rear of the shaft so I need instruction on how to get the shaft out first. Thanks.
Nov 10, 2008 at 9:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Usually a prybar is needed in this situation. You have to pry the shaft out, being careful not to harm any nearby components or lines. You can also try using a rubber mallet to tap the shaft out. Whichever is easier and more convient for you.
Nov 11, 2008 at 1:05 AM
