2004 Chevy Tahoe tire sensors
79,000 MILES • V8 • 2WD • AUTOMATIC
ERNEST8008
i just bought a tahoe and the check tire presure came on the dash. I checked the tire presure and then reset the senors. Now it say sevice monitor system on the dash. Thats not the only problem, after i reset the senors the speedometor is not working properly. It says im doing 70mph while the tahoe is in park. Do you think when i reset the semors that is messed upi the speedometor too.
Feb 27, 2008 at 9:06 AM
BRIAN 1
  • 1,030 POSTS
you have 2 different problems,resetting the tire pressure has nothing to do with the speedometer.been having alot of problems with the ipc's on these vehicles.as far as the tire pressure monitor it might have to be relearned or you might have a tpm sensor or sensors bad.here is a bulletin to reference.Some customers of 2003-2004 model year Cadillac Escalade, Escalade ESV, and Escalade EXT; Chevrolet Avalanche, Silverado, Suburban, and Tahoe; and GMC Sierra, Yukon, and Yukon XL vehicles have reported that one or more of the instrument panel (IP) cluster gauges stick, flutter, or become inoperative. This may cause inaccurate readings, including the speedometer and fuel gauge.
This special coverage covers the condition described above for a period of 7 years or 70,000 miles (110,000 km), whichever occurs first, from the date the vehicle was originally placed in service, regardless of ownership.
Dealers are to replace the instrument panel cluster after the condition has been verified. The repairs will be made at no charge to the customer.
this might help.
Feb 27, 2008 at 12:24 PM
