2004 Chevy Tahoe right blinkers
SNEWHOUSE
Electrical problem
2004 Chevy Tahoe
2004 chevy tahoe right side blinkers will not work, including console indicator light, and mirror--left side is fine. The fuse was blown, replaced it, it blew immediately, replaced the front & rear bulbs, replace fuse, blew immediately. Any suggestions?
Feb 5, 2009 at 12:43 AM
RACEFAN966
  • 5,029 POSTS
Ok does the hazzards work on both sides? Have you checked the turn signal flasher? Do you have a digital multi meter and do you feel comfortable doing some tests if needed? Get back to me and we will go from there.
Feb 5, 2009 at 2:02 AM
SNEWHOUSE
The hazzards only work on the left side. When I turn the right blinker on, it makes one clicking noise, then stops. How do I test the turn signal flasher? Or should I just replace it? I do have a digital multi meter & I feel comfortable doing some tests if needed. If you describe the tests I will do them tonight. Thank you!
Feb 5, 2009 at 6:49 AM
RACEFAN966
  • 5,029 POSTS
If you are getting power to the turn flasher relay the they will not blink then according to what I can find replace the turn signal flasher.
Feb 6, 2009 at 2:18 AM
