2004 Chevy Tahoe Loss of power steering, power brakes at lo
WHUMPHREY152
  • 2004 CHEVROLET TAHOE
  • V8
  • 97,500 MILES
When the engine is idling or running at low rpm's (1-3) the power steering and power brakes loose the "power" and becme manual. However during higher rpm's the power steering and power brakes are normal.
what can be done?
Saturday, July 4th, 2009 AT 12:02 PM
JDL
  • 16,098 POSTS
Hello, does your vehicle have the hydro-boost system? On this system, the power steering pump supplies hydraulic pressure for both the brakes and steering. I don't know if you need a new pump? I have heard of using a smaller pulley on the power steering pump to speed up pump rpms at lower speeds. Maybe your local front-end shop can point you in the correct direction.
Saturday, July 4th, 2009 AT 1:21 PM
WHUMPHREY152
I believe it has a steering pump?
Saturday, July 4th, 2009 AT 1:27 PM
