2004 Chevy Tahoe Interanl heat problems
130,000 MILES • V8 • 4WD • AUTOMATIC
SEARSJNG
Seems I have a thermostat problem. Engine heats slowly and I do not get cabin heat to the set point until I reach freeway speeds. In most cases is 1 hour of travel before I get to a freeway. Cannot determine where the thermostat is located.
Searsjng
Jan 27, 2009 at 7:23 AM
BRITE IDEA
If you follow the lower radiator hose back to the engine you'll see the thermostat housing.
Feb 7, 2009 at 1:25 AM
