2004 Chevy Tahoe HELP!
2004 CHEVROLET TAHOE
87,000 MILES • V8 • AWD • AUTOMATIC
CHANEY47
The traction control light and abs light stay on all the time. Ive been driving it for a few months like that, then today I drive it, come home and park it, go back out later that night to drive it and it wont start, wont do anything the only light that comes on when I turn the key over is the water pump light I think. Help what is wrong!!!!
Nov 8, 2008 at 2:07 PM
MASTERTECHTIM
  • 4,750 POSTS
first thing to check is the batteryand battery connections. if the positive battery termianl has two cables going to it then the lead spacer between the 2 cables is probably melted. if bettery and connections are good and you get nothing when turning the key to run then i would suspect a faulty ignition switch. first check the fuse block for power at the fuses that should have battery power all the time then check the ones that have power with the key on and see what we are missing
Nov 8, 2008 at 9:44 PM
CHANEY47
Okay so we replaced the battery and the tahoe is running fine now, but you can you help with the lights on. The traction control light and abs light have been on for months...do you know what will fix this? Or maybe what is wrong?
Nov 11, 2008 at 12:32 AM
MASTERTECHTIM
  • 4,750 POSTS
there are so many possibilities of the problem. in my experience it is usually a bad wheel speed sensor or the abs unit itself. you willl need to have the ebtcm electronic brake and traction control module scanned by a repair shop to determine the trouble code then we can go from there.
Nov 11, 2008 at 9:05 AM
